Is there no way to directly pair my chime with the video doorbell without a base station?
The Arlo Engineering team is working on implementing compatibility between the Arlo Video Doorbell and select Arlo Smart Hubs and base-stations. Stay tuned for more details as we prepare to release more details surrounding this upcoming support in the coming months.
There is no way to pair the Arlo Chime to the Video Doorbell (with or without a base station)..
@Spatman wrote:
The Arlo Chime works with the audio doorbell but not the video doorbell? That’s quite an oversight in the design.
Indeed. And the documentation on how the video doorbell works is pathetic. So that is little help.
It does say:
The Arlo Video Doorbell requires a wired doorbell and chime
with voltage between 16V AC and 24V AC, and a 10VA
transformer.
But who knows what that means?
Just another user
@michaelkenward wrote:
@Spatman wrote:
The Arlo Chime works with the audio doorbell but not the video doorbell? That’s quite an oversight in the design.Indeed. And the documentation on how the video doorbell works is pathetic. So that is little help.
It does say:
transformer.But who knows what that means?
Well, it means a mechanical or digital chime that works with an ordinary doorbell. It's not strictly true, since the video doorbell can be set up w/o such a chime if you want to do that. But you do need the transformer.
Not sure how to word that to make it more clear, other than to add a sentence saying that it won't work with the Arlo Chime. Though it'd be best if they just added support for the Arlo Chime. If they were to do that, I think they would require a base station.
I bought a video doorbell, chime, and Arlo ultra system only to find that the doorbell can’t talk to the chime or take advantage of the base station!
This seemed like a given based on all the documentation, marketing materials, and competing products. I don’t have a traditional chime at home so now I have a silent doorbell...
I’ll have to return the whole thing soon if I don’t know your plans for better integration.
I'm in the same boat here too! Think they are sending me another unit to try. If that doesn't work; its time to return the product as it doesn't function as intended. Similar to the audio doorbell issues I've had for over a year now - doesn't function as intended.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
