  • 6 Replies
  • 3062 Views
RKLimes
I'm looking for information on how to choose which google speakers tell me someone is at the door. I don't want every device in the house yelling at me whenever someone rings the doorbell.
6 REPLIES 6
ShayneS
Hey @RKLimes,
When you open the home app, can you select your doorbell by holding down the tab created for the doorbell within the Home app dashboard > Top Right tap the cog wheel/Settings > Do you see any options to Mute or turn off the Device for announcements? Can you repeat these steps for the Doorbell and Google device listed in the device card/Home screen.
RKLimes
Yes, there is an option there for voice notifications, but it's a single toggle which applies to all speakers and displays.  I would like to select which devices give me the notifications, since having it on all of them is absurd.
ShayneS
You should have the option per device.
RKLimes
I agree that I should, but these are all of the available options looking at the doorbell.
Each of the devices (speakers and screens,) have their own option to disable notifications generally, but I don't want to disable all notifications - just the doorbell rings.
I'm guessing this isn't possible.
ShayneS
Let me double check on this for you.
ShayneS
Hi,
We had a PLM look in to this and it looks like if you create a new home then add the desired speaker and the Doorbell to that same home/room this should allow you to choose which device to receive notifications.
It appears to be a limitation with the Google integration, but this should allow it to work. Hopefully that helps
  • 6 Replies
  • 3063 Views
