Have installed a Arlo Vide Wired doorbell with the transformer inkluded in the package.
Connected to my base station VMB4540r2.
I can se video, talk etc from the web portal or app. Problem is when someone press the button i get a call, video frame is greyed out and i cant answer, no sound. After 11 sek the call i shut down.
Same problem on andriod and iphone.
Video quality is set to low. Cant find any restriction on the phones.
What is the problem?
Which version of the Arlo Mobile app are you two using, as well as iOS version?
Hi ShayneS, I am using app version 3.5.5 (2967), and was having issues with iOS 14.8 beforehand, and the same issues using iOS 15 currently.
Hi @Dbensette
I have a few additional questions for you:
Do you have the ability to test this issue with an Android device?
Do you have the ability to check with another iPhone?
Does this issue happen with the iPhone 12 Pro Max only?
Does this issue occur all the time or sometimes only?
Thank you
I don’t have any android devices unfortunately.
I tried with my iPad mini, and it seemed to work fine. But, also tested again with my iPhone and it worked as well. I have mainly noticed it doesn’t work when I am not home. I will bring my iPad to work tomorrow to test if it works on the iPad while I am away.
I can also test with a different iPhone later this evening. But it may be more of a problem when I am away from the house possibly?
Usually all the time when I am not home, but I tried answering on the iPhone while I’m home today to test it out, and it was working correctly. I usually don’t answer on my phone when I am home…
I hope that helps a bit…? I can keep testing different ways later today and tomorrow.
Thank you for the detailed information. The Dev team is actively investigating so any new info is appreciated.
Now while on 5G cellular, twice in a row it froze my phone up.
@ShayneS I will send the logs again to you now if that helps any. Thanks.
Sure, it won't hurt & whenever you can provide the information from the other couple questions in my previous post, you can send it in with that info.
Thank you!
Maybe it’s the model of phone having issues?
Did you retrieve/send a log after replicating?
Hello,
Can you check to see if you still experience this issue with the latest version of the Arlo mobile app v 3.5.10? If you do not see the update, please remove and reinstall the Arlo app.
Are you still experiencing this issue with your doorbell?
The issue I was having has seems to be resolved lately as it’s working as expected now. I never did figure out what was wrong, I sort of gave up on it but it’s working again now. 👍
Thanks again.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
