I don't know what resolution you're running your doorbell at (I was at 1536x1536), but when I changed that to another resolution (1080x1080) live video and recorded video on 1080 started working. I switched it back over to 1536x1536 resolution and it resolved my issue. Live video and newly recorded content working again. I'd give that a shot and see if that works for you.
fuzzcub,
Check your phones settings to make sure the correct permissions are enabled:
For Android:
Navigate to phone “Settings”
Select “Apps”
Scroll down to “Arlo”
Ensure that the Arlo app has “Camera”, “Microphone” and “Phone” permissions granted
Thanks for the suggestion. I confirmed that those permissions are active. I have a video doorbell and two Pro 2 cameras. The 2 cameras still display recordings and live video within the app. The video doorbell did until the recent firmware update. I'm wondering if it is a codec issue related to the firmware update.
fuzzcub,
Are you using a VPN by chance? Take a look at this post: https://community.arlo.com/t5/Arlo-Video-Doorbell/Answering-a-doorbell-ring-with-no-video-or-audio/m...
Yes, I just turned off the VPN, but had the same result. Which is live doorbell video shows a black screen, while I'm able to hear audio. The two Pro 2 cameras still work fine with live video within the app. All 3 units had been working fine until this week.
fuzzcub,
I will reach out to you in a private message to gather more information on this issue.
Exia7891that did the trick, thank you so much! Everything is working again.
This worked for me. Changed the video resolution and BAM good to go.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
