@Retired_Member wrote:
My wired doorbell has always recorded in color at night but is now b/w.
This does depend on how much light there is outside. Is this happening with every single recording, or just some?
You could try a test with more outdoor illumination and see if it reverts to color.
Personally I prefer a high quality nightvision recording over a low quality color one.
You need sufficient light to get color. B&W requires less light. The Ultra "flashlight" on live view turns on the spotlight on the camera to allow color recordings.
There have been recent comments about this happening. All I can say is that with sufficient light the doorbell records in color - mine does.
(Sorry for the rant. And there is even a third problem now!)
InJayMama,
If you removed and readded the doorbell, it will no longer be shared with your husbands account. You need to go back to your Grant Access settings and toggle sharing on for the doorbell for it to be visible again on his account.
If you're continuing to experience the same issue, I encourage you to contact the Arlo Support Team to investigate further: https://www.arlo.com/en-us/support/contact.aspx
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
