  • 7 Replies
  • 1626 Views
trentrockport
I just added an Essential (Video) Doorbell to my system that has four Ultra 2 cameras and a VMB5000 base station. When I try to connect to it through the application, either in Windows or on my iPhone, I get a message "The request timed out" with an Okay button. The four cameras still work fine. The doorbell reports that it's connected to the base station same as the cameras. When I do get a picture from the doorbell's camera, it's either 100% gray or I just see the first few rows of pixels with the rest distorted.
How to correct this?
ShayneS
I see a high RSSi value for your doorbell. This is caused by a few factors, but being further away from your base station and multiple walls etc this can affect the range and streaming capabilities. If you can move your base station a little bit closer you should hopefully see an improvement.
You can also try connecting directly you your wifi (https://kb.arlo.com/000062514/How-do-I-connect-my-Arlo-device-directly-to-a-WiFi-router) router to see if that helps.
7 REPLIES 7
trentrockport
UPDATE (apparently we can't edit our posts...)
If I reduce video quality to 720x720 it works. I'd much rather use this at the resolution I paid for.
trentrockport
UPDATE to UPDATE (apparently we can't delete posts either)
If I reduce the video quality to 720x720 it works SOMETIMES.
ShayneS
Does the same occur on wifi and mobile data? Do you experience the same issue over the web portal on a pc?
trentrockport
The same thing happens WiFi/Mobile and on the Web portal. Worth mentioning: this is a fairly large house with a 42' x 58' footprint.
ShayneS
trentrockport
Moving the doorbell from the Base Station to my WiFi appears to have fixed that problem. Thank you
ShayneS
Perfect, let me know if you have any other questions.
Thanks for the update
  • 7 Replies
  • 1627 Views
