Gabel2019,
Silent mode disables both incoming calls and chimes. For more information on this, take a look here: How do I receive incoming calls on my smartphone from the Arlo Audio Doorbell?
Gabel2019,
The development team is paying very close attention to feedback on enhancements like what you suggest here. I will pass this feedback along to the development team for consideration.
The Arlo Audio Doorbell has the feature to turn off the incoming call but leave the chime on. See the link https://community.arlo.com/t5/Arlo-Audio-Doorbell/Turn-off-calls-when-doorbell-is-pressed/m-p/167324.... How come the Video Doorbell doesn't have it?
I liked the video doorbell and I even thought the subscription was ok, not to expensive but in the end I discontinued the subscription since I could not turn off the call feature without also turning off the chime. Unfortunately when you don’t have a subscription no recordings are saved. I find the doorbell pretty useless without it actually recording and storing a video for at least seven days just like the my other Arlo cameras. But I also find the call feature so... annoying. I’m looking for alternatives. Maybe the Ring doorbell?
Please enable this feature as soon as possible.
ArtBarr,
This feature is now available within your Arlo Video Doorbell settings.
Log in to your Arlo Mobile app and navigate to Settings > My Devices > select your Arlo Video Doorbell > Silent Mode > toggle Incoming Call
ArtBarr,
After further investigation it appears this toggle may be missing for the Android client (should be present and working on iOS).
I will review this with the development team and provide an update as soon as I have more information.
I am using the latest version of iOS. The setting is not there.
I was excited to see this feature was enabled and encountered the same thing on iOS when going to silence mode. If you turn silence on, it then opens up two more options, allowing you to silence the chime, calls, or both. Awesome that this is now possible!
Did you check to make sure your Arlo app has updated to the latest version? It’s working on all three iOS devices in our household.
I show version 2.15 (released March 2020) of my Arlo app.
And, I’m running the latest version of iOS but still not seeing the new settings.
What type of chime are you using?
Thats weird. I have a mechanical chime and think Im on the same app version. My app specifically shows as Version 2.15 (147) Released Mar 30, 2020.
I attached a picture of what it looks like in my app when I select silent mode. Sorry I couldn’t be more helpful. Doesn’t make sense to me why you wouldn’t have the same option if on iOS and same app version. Maybe the (147) after my version number makes a difference?
I have the exact 147 app version. Agree. Weird. I’ve checked another iOS device in my home with access to my doorbell and it does not show the settings either. Are you subscribed to the Smart or CVR plans? I’m currently not subscribed and don’t think that should make a difference. I’m still waiting to hear from Arlo tech support regarding the case that has been submitted on my behalf.
Another thought, is the doorbell connected directly to your home Wi-Fi or do you have it going through an Arlo smart hub? I just recently connected through the hub instead of Wi-Fi. Unfortunately, I don’t know if I had the silence options before or not.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
