Turn off calls when doorbell is pressed
It would be a good feature if you could turn off calls when the doorbell is pressed. I see there is a silent mode but that will still call the phone. Seems daft if you're in the house and the phone rings. Can we have a setting to turn off calls to phone please. Thanks
Hi @Glasto,
You should not be receiving any incoming calls if you toggled silent mode. Try to re-toggle the silent mode for the incoming call and see that helps.
Their isn't a feature If you're in the house and you don't want your phone to ring at all but the chime to sound?
After you enable "Silent Mode", you should see more options where you can toggle them separately. If you want the chime to still be on, you can toggle the individual sliders. See the screenshot below or check this article out: How do I enable silent mode on my Arlo Audio Doorbell?
Hi @jmmmmh,
It will immediately say as "leave a message" after someone hits the Arlo Audio Doorbell since turning off incoming call will reject the call from your Doorbell.
Hey @Sircoynie and @jmmmmh,
Currently, the "leave a message" feature cannot be disabled. We may consider this as an enhancement in the future. But feel free to post this idea on the Idea Exchange Board.
