Why not sync it to your base?
That may be a bad doorbell then. Try using the reset procedure listed in the doorbell FAQ here in the support section by holding the button for >10 seconds. You may need to swap at the store.
Your phone or computer must be on your home network (no VPN) so you can communicate with the doorbell. As it's set up Internet connection is needed to complete the addition to your account. So, yes, Internet access is needed but initially it's the home network that's needed. Your phone needs to be able to connect to both the doorbell and the servers.
Use the Contact Support link at the bottom here to see if they have suggestions.
My router has an option to disable the 5ghz signal. I did that while I set up the doorbell and then turned it back on. Seems to be working.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
