Friedland Power Kit Wiring
Hi,
I'm just looking to install the power kit but I'm not too sure where to put the wires with the current layout. Could you please advise.
Thanks.
Hi Nesian21
This How-To video should help with the installation process. https://www.youtube.com/watch?v=GMogHU9MyPI
@Nesian21 wrote:
Hi,
Do you have an install guide for the chime?
If not, a model number might help.
No install guide for the doorbell, it's circa 1970's
It is however a Friedland 454
FWIW, after googling it, I don't think it's compatible. It apparently uses a 6 volt transformer (or batteries). So check the ratings on your transformer.
But I think the power kit needs to be wired across 1 and 3 for the front doorbell (2 and 3 for the rear). That is based on this: https://diy.stackexchange.com/questions/196032/confused-about-strange-wiring-to-friedland-no-454-doo...
Cheers for that. I think you could be right. Will have to investigate further into a transformer.
Much appreciated.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
