Connecting to T-Mobile Home Internet with Arlo Essential Video Doorbell Wired Model: AVD1001-100NAS
  • 5 Replies
  • 4902 Views
Lowflyinggoose
Is it possible to connect the Arlo Essential Video Doorbell Wired Model: AVD1001-100NAS using T-Mobile Home Internet? I've setup a dedicated 2.4 GHz network using WPA2 security. I have a full Wi-Fi connection on my phone by the doorbell, but I can't get the doorbell connected to my network.
Using the reset button method, the doorbell will not read the QR code. Setting the doorbell up from scratch and holding the ring button, the QR code will scan but the doorbell cannot be found.
I think I've tried everything I could find in the troubleshooting tips, including enlarging the QR code, disabling VPN, and turning off cell service.
Lastly, all my other Arlo cameras have connected without issue.
If anyone has any additional suggestions, please let me know. Thanks.
Lowflyinggoose
I was able to get connected. I’ll share what I did in case it helps someone in the future.
The T-Mobile Internet router has the following settings:
Frequency band – 1) Automatic, 2) 2.4 GHz, 3) 5 GHz
WPA Version: 1) WPA/WPA2, 2) WPA2, 3) WPA2/WPA3
WPA Encryption mode: 1) TKIP & AES, 2) AES
The only configuration that works is 2.4 GHz frequency, WPA/WPA2 security, and TKIP & AES encryption.
When connected to that network on my phone, it is flagged as “weak security”. I’m not thrilled that the doorbell has weak security, but none of the other options worked.
5 REPLIES 5
I did try this a while back (with success), but my doorbell is connected to a VMB5000 base.
If the doorbell doesn't chime when you present the QR code, then the issue is that it isn't able to scan it.  Fiddling with the angle can help with that.  You can also generate a code using https://qifi.org/ and print it.
If the network name or password has punctuation in it, then try removing that.  There are some characters that don't work, and unfortunately Arlo has never said which ones.  Also, they haven't said if these characters are the same for all cameras or not.
Lowflyinggoose
Thanks for the reply and great suggestion about punctuation in the network name and password. I renamed the network name and password to letters only (removing a dash and some periods). Unfortunately, I still cannot connect the doorbell to the network. I was able to read the QR code (heard the chime), but after a few minutes of "looking for Arlo video doorbell", no doorbells could be found.
I have been able to connect my other cameras, which are the Arlo Pro 4 spotlight cameras and Arlo-Q indoor cameras.
Is it possible that the doorbell can't connect to the T-Mobile Home Internet network without using a base?
I didn't test that, but it should be able to connect to the wifi ok.
Did you disable cellular data on the phone, and make sure it was connected to the correct wifi network?
Lowflyinggoose
It definitely uses 2.4 gHZ and WPA2.  But it doesn't need TKIP - just AES.
  • 5 Replies
  • 4903 Views
