Can I wire two arlo video doorbells ?
  • 1 Reply
  • 1199 Views
Southland53
Can I wire two arlo video doorbells (one at the front door and one at the rear door) to an existing 16V 10VA system or will the current draw be to much?
GordonScot
Yes, as long as you have front/rear labeled on your chime (3 connecting screws) then connect both modules inside the chime.  Current draw shouldn’t be a issue....what are the chances both are rung at the same time.
  • 1 Reply
  • 1200 Views
