A red light appears on my Arlo Video Doorbell
I just received my Arlo Video Doorbell. I installed the power unit and then the video doorbell and do not get the white lights, I get a single red light above the door chime button. I have attempted to re-install several times and continue to get the same red light. Is the unit defective?
the solid amber light means that the doorbell is not receiving enough power. This can happen for a short period of time after a new installation as the internal battery may need 15 minutes or so to fully charge. If the amber light does not turn white after 15 to 30 minutes there are two things to try/consider.
1) you may need to change the switch setting on the power adapter you installed at your chime to the Bypass mode. If that doesn't resolve the issue, then
2) you will probably need to get a more powerful transformer.
Brian
Hector111,
A solid amber LED during setup indicates the doorbell is not receiving enough power. For more information, take a look here: What do the LED behaviors on my Arlo Video Doorbell mean?
LouisvilleColo, Thom84
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Try taking some time to troubleshoot by disconnecting, unplugging, resetting. I also had difficulty with the doorbell detecting my WIFI also and had to try several times to connect but could be due to distance of doorbell to my router.
I think the OP might be referencing the IR LED, which is a single red LED above the chime circle.
https://kb.arlo.com/000062359/Arlo-Essential-Video-Doorbell-Wired-Product-Tour
@LouisvilleColo wrote:
Needs 24v to work.
No, the range is 16-24v for the wired doorbell.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
