Lag for Audio while Live
When I click on the doorbell live and try to speak to the guest, there is a 6 - 7 second lag. Is there a way to fix this? I have 400mb internet and have strong cell signal.
That's about right for the lag. You're creating a connection to the servers and then back which takes time to wake everything up.
Edit - I replied based on the initial lag, not the lag when the connection is already made. Which one are you referring to? With the connection already made, lag shouldn't be that long as long as the doorbell isn't struggling with the connection to your base or router, depending on how it's connected.
alarm
Arlo Video Doorbell
AVD1001-100NAS
Doorbell
