I have a wireless video doorbell but can’t get silent mode to work. I flip to silent mode, it appears on (turns blue) but still getting notifications on my phone, thoughts?
this is a brand new doorbell
Best answers
Silent mode only affects what happens when the doorbell is pressed - letting you
- prevent the chime from sounding and/or
- prevent the doorbell from calling your phone.
It doesn't have any effect on motion-triggered or audio-triggered notifications. There are a couple of ways you can disable those, including
- using a mode that is set not to notify you
- using the temporary notification mute feature
- disabling some notification types from the smart notifications settings for the doorbell
- disarming the doorbell
Can you please elaborate on each of these. None of them seem intuitive. I've found Feed Settings from the Feed tab at the bottom of the screen; there are 16 event types to select/de-select but this seems clunky for simply wanting to stop notifications temporarily on one doorbell whilst builder is going in and out all day long.
Hi @splinternet
You can temporarily mute your notifications by navigating to The Profile icon in the top left > Notifications > Mute Notifications.
OK, thanks. Is it possible to mute only a specific doorbell? I'd want my other one to keep sending notificatons.
@splinternet Unfortuantely it's all or nothing for the mute feature. You can either remove the alert in the rule or disable the device from the app temporarily.
OK thanks 😞
@splinternet I'll be here to help if you have any further questions.
using a mode that doesn't notifiy you:
disabling some smart notification types:
disarming the doorbell (turning it off for a while)
