  • 8 Replies
  • 1871 Views
pnw1
I have a wireless video doorbell but can’t get silent mode to work. I flip to silent mode, it appears on (turns blue) but still getting notifications on my phone, thoughts?
this is a brand new doorbell
Best answers
  • StephenB
    Silent mode only affects what happens when the doorbell is pressed - letting you
    • prevent the chime from sounding and/or
    • prevent the doorbell from calling your phone.
    It doesn't have any effect on motion-triggered or audio-triggered notifications.  There are a couple of ways you can disable those, including
    • using a mode that is set not to notify you
    • using the temporary notification mute feature
    • disabling some notification types from the smart notifications settings for the doorbell
    • disarming the doorbell
8 REPLIES 8
splinternet
Can you please elaborate on each of these.  None of them seem intuitive.  I've found Feed Settings from the Feed tab at the bottom of the screen;  there are 16 event types to select/de-select but this seems clunky for simply wanting to stop notifications temporarily on one doorbell whilst builder is going in and out all day long.
ShayneS
Hi @splinternet
You can temporarily mute your notifications by navigating to The Profile icon in the top left > Notifications > Mute Notifications.
splinternet
OK, thanks.  Is it possible to mute only a specific doorbell?   I'd want my other one to keep sending notificatons.
ShayneS
@splinternet Unfortuantely it's all or nothing for the mute feature. You can either remove the alert in the rule or disable the device from the app temporarily.
splinternet
OK thanks 😞
ShayneS
@splinternet I'll be here to help if you have any further questions.
using a mode that doesn't notifiy you:
disabling some smart notification types:
disarming the doorbell (turning it off for a while)
  • 8 Replies
  • 1872 Views
