- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: Set Doorbell to have push notification and not...
Use the Disarmed mode for your doorbell. The doorbell will still ring your phone when pressed but no videos will be taken so no notifications, either.
iNo,
It sounds like you may want to enable Silent mode and disable the incoming call from the doorbell. Within your mobile app navigate to Settings > My Devices > select your doorbell > Silent Mode > toggle off incoming call. For more information see here: https://kb.arlo.com/000062169/How-do-I-receive-incoming-calls-or-voice-messages-from-the-Arlo-Doorbe...
Afterward, test to see if the doorbell is behaving as desired.
@iNo wrote:
Yes I have tried this as well, but I would like it to notify me at least if someone has pressed it at all. When completely silenced and disabled there is no notification at all that someone has pressed the button either and the call gets rejected
There is no way to turn the button press into a notification. So the only options are to depend on the motion detection to give you an alert, or to live with the phone calls.
FWIW, it would be nice if there was a way to get a notification (and like the other notifications, be something you can schedule, or set up with geofencing).
