Essential Video Doorbell wire-free not found
Removed video doorbell from wi-fi and tried to link it to a base station. Despite following all the steps precisely, it cannot be found. I tried it several times with two base stations both with firmware up to date. Then I attempted to hook it back up to wi-fi and now it cannot be found there either. Again all steps followed precisely camera scans QR code fine and I get the success tone. Then it just spins and spins. Doorbell is connected properly to wi-fi. For what it's worth mobile device I'm using to do the pairing is using latest Mac OS. Any ideas why I'm having issues? Thanks
What base station model(s) do you have?
VMB4000r3 and VMB4500r2. I've tried to connect to both with no success.
After removing the doorbell, did you complete a factory reset prior to attempting to reclaim it?
Make sure to follow these steps to complete the reset: How do I reset my Arlo Essential Video Doorbell?
I found the router freq HAS to be 2.4 G if that is required of your device. It will NOT connect to a faster or slower speed. I found that out through trial and error. My router has 5 AND 2.4 as it turns out. I was trying to connect with the 5G connection until I realized maybe I should try the 2.4G... Bingo!
Good Luck.
no problem on delay. I am not using a base station. I connect directly to my router at my home. The camera is for the front porch area. Anyway, 2-3 second delay doesn't sound awful to me? it could be so many things, including your internet provider. I would say we have a 2 second delay, but I have not truly timed it. Hope you find the answer you are looking for. I was only commenting on the process of connecting to wifi... I saw frustration out there with NO connection. That was me until I found out when they say 2.4G WIFI they mean ONLY that frequency. It won't scan and connect to any other. I also have 5G and that was my problem. Anyway. Good luck!!
