- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Doorbell rings phone upwards of 30+ minutes after ...
Doorbell rings phone upwards of 30+ minutes after button press
Has anyone had the luxury of getting ghost phone calls from your doorbell long after someone has pressed it?
We've had deliveries ring the doorbell, hear our wired chime but not the fantastic Arlo chimes. Then out of no where, sometimes up to 30-40 minutes later, all Arlo chimes ring and the incoming call from the doorbell trigger.
My experience thus far has me very tempted to go back to something that "Rings" correctly when used.
When playing the recording what are you seeing? Is it just blank or is it showing something different?
There is no recording, it's ringing through to my phone for live video from the doorbell, but at this point whoever rang the doorbell is long gone. My other Arlo camera that is positioned above the front door actively recognizes movement and people while the doorbell registers stuff (if anything) minutes later.
Are you still seeing this same behavior?
Previously, I was told to add the device directly to my wifi to avoid "interference" as videos would be half green or distorted.
When this issue started, after nothing else worked I decided to reconnect it to the Arlo Base. I had to reset the device 3 times before it started working correctly, or to get it to connect via QR code. The doorbell rings but as of yet I can only remember 2 times the video calling feature working when someone is waiting at the door. Thus far the Arlo Ultra that is also positioned on our porch is far more reliable than this doorbell device has ever been.
(As an aside, please fix the QR scan camera view in your app to work with later iPhone model cameras, as you can't zoom into the microscopic QR code with the default camera. I end up having to snap a picture, zoom into the picture on an iPad, and scan that to connect within the app.)
So it either rings after a long delay or you do not get the call at all is that correct?
Start by removing the doorbell from your account, reset it and add it back to see if the gremlins are gone.
Old user interface that uses Library for recordings
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
New UI that uses Feed
https://kb.arlo.com/000062934/How-do-I-reset-my-Arlo-Video-Doorbell-Arlo-Secure-4-0
If that doesn't help, use Settings, support from the app. Select the doorbell and scroll down to Contacts to talk to official support.
Thank you for providing that information. I have passed it onto our development team who is currently looking into this. I will provide an update as soon as possible.
Are you still experiencing this same behavior?
I gave up testing this due to the reliability of the doorbell, and instead rely on the Arlo Ultra 2 positioned on the porch.
Doorbell itself is a "sometimes it works, sometimes it doesn't" in regards to the smart features, but it still rings the hardwired chime.
Hi,
I’m experiencing the same thing, but only 1-3 minutes after the doorbell has been pressed. The call rings our cellphones straight away, but the chime makes it’s sound 1-3 minutes afterwards. I’ve tried to restart the doorbell and chime, removed and added them again in the app, etc., but nothing works. The delay when speaking to someone through the doorbell is also very long. Aprox 4-6 seconds every time which is extremly annoying as conversations are almost impossible.
Specs:
- The doorbell is wireless and full battery
- Chime and door bell are 6-7 meters apart
- I have a hub with SD-card installed + subscription
- They are both connected to a 750/750 Mbit internet which is very stable as I work lots from home
- Both have full WIFI-signal
What is going on?
Our development team is looking into this. I will update as soon as possible.
@MDolsen can you please provide a recording of when the doorbell is pressed and when the chime goes off?
Do you really mean that I’m suppose to record for 1-2 mins until the chime goes of? That will be a huuuge video to upload.
it’s very simple:
1. I press the doorbell and it makes a sound and it calls our phones.
2. After 1-2 minutes, the chime goes of. Very often in the middle of the conversation to the person pressing the doorbell.
Hi and yes.
A visitor rang my doorbell just now and my phone startet calling right away as it normally does. I used 40sec to get the door and mid conversation, the chime rang, about 1,5mins after they pressed the doorbell.
Can you please send me a dm of a video showing what you are seeing?
Hi, somehow everything works fine now and have done so for the past 3 weeks. I will keep an ear on the chime to see if it rings or not.
i will post here if it happens more.
Ignore my last post on the thread since the doorbell and chime is still having a delay.
I have DM’ed you about my recording.
I got the DM thank you for providing that. Our development team is currently looking into this. I will update you as soon as possible.
Hi,
Have your developers found anything?
Latest happenings is that yesterday and today (5min ago), the chime rang 1,5mins after the doorbell was pressed. Our phones got notifications straight away, so without them nearby, our doorbell is useless as most people leave if nobody answers within 2mins.
Was there any chance the iPhone did not have internet when this occurred?
