- English
- Doorbells
- Arlo Video Doorbell Wire-Free
- Re: Chime 2 AC2001-100NAS Can't get it connected
Successfully installed the wireless doorbell camera and am now trying to set up the Chime 2 to go with it. I select add new device and select chimes, chime 2, and then scan the code on my device. I then get a popup saying:
Connect to device
Arlo app wants to use a temporary wi-fi network to connect your device Arlo_g45z
Cancel Connect
So I select connect. It then asks me for my wifi and I select it from the list and key in the passcode.
After a minute or so I get the following popup:
Unable to join Arlo_g45z
Please make sure the chime you scanned is plugged in (which it is)
Cancel Try Again
So I try again and pretty much go through the same process and end up not connected.
screen print
second screen print
I've tried resetting the chime 2, have tried multiple android phones and my tablet, but get the same results on all.
I've tried resetting and also trying to connect using different phones and a tablet. Always the same response
I opened a case with support, but they seem to be ignoring me...
I didn't find arlo support very helpful.
