  • 7 Replies
  • 2779 Views
  • 4 Likes
lamnob
Successfully installed the wireless doorbell camera and am now trying to set up the Chime 2 to go with it.   I select add new device and select chimes, chime 2, and then scan the code on my device.   I then get a popup saying:
Connect to device
Arlo app wants to use a temporary wi-fi network to connect your device Arlo_g45z
Cancel   Connect
So I select connect.  It then asks me for my wifi and I select it from the list and key in the passcode.
After a minute or so I get the following popup:
Unable to join Arlo_g45z
Please make sure the chime you scanned is plugged in (which it is)
Cancel   Try Again
So I try again and pretty much go through the same process and end up not connected.
7 REPLIES 7
lamnob
screen print
lamnob
second screen print
lamnob
I've tried resetting the chime 2, have tried multiple android phones and my tablet, but get the same results on all.
lamnob
I've tried resetting and also trying to connect using different phones and a tablet.   Always the same response
I opened a case with support, but they seem to be ignoring me...
Madfire
I have same problem. Tried 2 different chimes same thing. I talked to support 4 times. They don't know. I'll just take it back and use the jumper wires that came with doorbell camera and hardwire it. Use my regular doorbell as the chime. This also keeps battery charged I am told
lamnob
Oddly enough, I kept trying and one day it actually worked. I reset the chime, deleted the cache in the app and tried installing and got the unable to join, selected try again and it worked. I can't explain why because I had done the same procedure before.
I didn't find arlo support very helpful.
  • 7 Replies
  • 2780 Views
  • 4 Likes
