Can't connect to chime 2
I can't connect to chime 2. Scan's QR code but then doesn't connect to arlo_6663. Just get cannot join arlo_6663 message. I am using 2.4 ghz. Am using iphone 15 pro max.
I don't have iOS devices but on ANdroid there's a setting to (dis)allow connections to open networks. Check your phone's WiFi settings to see if that exists and is set properly.
@amoore70 is there any way you can try to onboard it from a different mobile device?
I've installed a new Sky router today and wishing I hadn't. The reason being I've spent 2-3 hours setting up my 2 wireless doorbells and trying to add my five Chime 2's. Even o...
What is this all about then? I've re-installed the Arlo Secure app and other than a different router (2.4GHz) with a different name, nothing else has changed.
Well that didn't work too well, trying to include a picture. To repeat, I get to the point of naming the Chime 2 but when I do I get a yellow banner saying "Internal error".
Are you still seeing this same behavior?
