My AVD2001 wire free stopped working about a day ago. I performed a factory reset to the device, a couple times. Everything seems to work fine during set up, but on an update page in the app it stalls and says "Update cannot occur at this time." I have tried the cycle all over again and it still doesn't yield results.
The device appears in the app but says "Offline." I have searched the forums and have found issues that are similar, but solutions dont seem to work.
Try rebooting the phone and reinstalling the app. Bring the doorbell closer to your router to see if that helps.
I have tried that multiple times.
The frustrating thing seems to be the update stage of the "add device process." Everything seems to connect, there is even a video showing on the app of the camera allowing you to position it, but it wont update the firmware. I select "Try Again Later" and the devices shows up in the app but it then shows as "not connected."
I have also tried to change the network and it still doesn't work.
I feel like I am out of solutions. Any other ideas?
When you reset, did you follow the procedure found here?
https://kb.arlo.com/000062346/How-do-I-reset-my-Arlo-Essential-Video-Doorbell
I've had a similar situation but don't recall the specific fix. Might have been a reset or a different doorbell. You may need to use Settings, Support to talk to support about a possible RMA.
I have done this multiple times, to no avail. I am not able to see a support number to call on the website.
There isn't one. You need to access support via the app. If you have a subscription for the doorbell (paid or trial), you should see a phone icon. It will be grayed out when the support center it closed. (It's open 6 am to 6 pm US pacific time).
If you can't onboard the doorbell at all, then post back - the mods can escalate that for you.
