- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Re: Introducing Arlo Video Doorbell - 2nd Generati...
Introducing the 2nd generation of the Arlo Video Doorbell, now offered in both 2K and HD options. While you’re away from home, running errands, working, or on vacation, you can count on the Arlo Video Doorbell to let you know what’s happening at your front door.
Protect your door and more. Video Doorbell protects your front door with clear HD 1080P resolution, Night Vision, and Integrated Siren. Respond to visitors with 2-way audio or send a quick reply message. · HD Video Doorbell · Updated seamless Bluetooth onboarding · 180° field of view · Built-in battery with new technology for long life · Night Vision · Sleeker form factor with newer battery technology
Protect your door and more with crystal-clear details. Video Doorbell protects your front door with crystal clear 2K resolution, Night Vision, and Integrated Siren. Respond to visitors with 2-way audio or send a quick reply message. · 2K Video Doorbell · Updated seamless Bluetooth onboarding · 180° field of view · Built-in battery with new technology for long life · Night Vision · Sleeker form factor with newer battery technology
Post a reply or visit Arlo Support if you have any additional questions or need more information about the Arlo Video Doorbell - 2nd Generation
Thank you for being part of the Arlo Community!
@JamesC wrote:ale_loo,
Correct. As long as you have local storage enabled on your VMB5000: https://kb.arlo.com/000062818/How-do-I-set-up-local-storage-backups-using-my-Arlo-SmartHub-or-Base-S...
ok, as long as ARLO fixes these outstanding show-stopper issues with the app, I might consider getting 1 for myself.
What issue are we talking about?
- automation leave and automation arrive not working all the time (sometimes they do). Context: 2 devices = android + iPhone. Both apps with "Feed". Both devices logging in the same account. No subscription but SmartHub as local storage.
Many thanks.
Alex
I see it’s now compatible with a smart base, but is it still not Apple Home compatible?
I would also like to request an update to the compatibility with HomeKit issue.
Hi there,
How many times does the doorbel-led of the Arlo Video Doorbell (2nd gen) flash on detection before it stops.
In my case its stops after two pulsating(heartbeat) flashes. After that it stays dark and the doorbell is hard to find in the dark and operate by the visitor. Is that normal or is there a malfunction.
HaBo10,
This sounds like normal behavior. Once the doorbell detects motion again, it should start pulsing again.
Following up on HomeKit - any word on compatibility? My Doorbell 2nd generation connects to the base station after the firmware update but still doesn’t show up when I connect that base station to HomeKit.
Same here. Successfully added my doorbell to the smart hub, but the doorbell still doesn’t show up in HomeKit…
Because it's not compatible with homekit yet.
None of the Gen2 camera models are in the "applies to" list here:
Ah! thanks for the clarification.
@JamesC wrote:Base Station/SmartHub compatibility is now available for Arlo 2nd generation devices. For those that already have your Arlo 2nd generation device onboarded, you will need to remove the device from your Arlo account and re-onboard to see the option to sync with your Base Station/SmartHub. The following firmware or newer is required for this integration.
Compatibility list:
Arlo Essential 2nd Generation Outdoor - VMC2050, VMC2052 – Firmware: 1.5.0_1048_85f53f3
Arlo Essential 2nd Generation Outdoor 2K - VMC3050, VMC3052– Firmware: 1.5.0_1048_85f53f3
Arlo Essential 2nd Generation Indoor - VMC2060 – Firmware: 1.5.0_1048_0e78ae4
Arlo Essential 2nd Generation Indoor 2K - VMC3060 – Firmware: 1.5.0_1048_0e78ae4
Arlo Video Doorbell 2nd Generation - AVD3001 / AVD4001 – Firmware: 1.5.0_1059_eb10395
Compatible Base Station/SmartHub:
Base Station VMB4000 – Firmware: 1.25.0.1_4591_0201bb2
Base Station VMB4500 – Firmware: 1.25.0.1_4541_0201bb2
SmartHub VMB4540 – Firmware: 1.25.0.1_1680_0201bb2
SmartHub VMB5000 – Firmware: 1.25.0.1_1762_0201bb2
hi @james , can I confirm that AVD2001B-100AUS (I guess it is Essential video doorbell?) is NOT supported and so NOT compatible with SmartHub VMB5000? (the doorbell is NOT on your list)
Alex
This announcement thread is focussed on the Gen 2 doorbells. The AVD2001 is a first gen doorbell model, and was therefore not included.
But it is fully compatible with the VMB5000:
Hi, is there any timeline on when Apple HomeKit compatibility will come to these 2nd gen doorbells?
I just installed a second gen doorbell camera. You said the old one used to cover up to 5 M, but the newer model does only up to 3 M. I noticed that my new doorbell cam rarely captures any vehicles driving by or walkers by. Is this why?
Note I don't work for Arlo.
The reduced motion range could well be the main cause here. But you try increasing the motion sensitivity.
A long motion detection in the doorbell isn't always a good thing, since the camera can't really be aimed. When on battery, a lot of distant motion can cause excessive battery drain (as well as creating a lot of unwanted notifications and recordings).
Good afternoon
I see live images of the doorbell on my telephone and on the telephone of my partner.
But I don't want my partner to see all the time who's at the door.
What can I do so my partner doesn't see live images / feed on certain moments ?
Thank you very much !!!
Demièstre,
Take a look here to see options for users with shared access: https://kb.arlo.com/000062945/What-privileges-do-my-friends-have-when-I-grant-them-access-rights-in-...
Currently, it is not possible to share access and restrict their access during certain times. You would need to remove the shared user if you wish to restrict their access after sharing.
Thank you very much for the info ! It's much appreciated !!
when i try answer the arlo doorbell on my phone it takes 15-20seconds to connect. Any idea why such a long time lag ?
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
