- English
- Doorbells
- Arlo Video Doorbell 2nd Gen
- Re: Battery on Doorbell Gen2 drains after one week
New Doorbell battery drains after about a week. Have charged it three times now and it lasted about the same each time. Very little activity has occurred in this timeframe
Are you using activity zones? If so, delete them to ensure you see ALL recordings since the servers discard recordings determined to be outside any zones.
Also try bringing the doorbell indoors for testing to see if there's a difference. It could be a signal strength/quality issue.
It is too soon to tell if the reset has resolved the issue. In another week or so, will know.
Reset of doorbell did the trick. Thanks much.
greg
2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
intermittent
Mechanical chime
no app model
noise
Phonecall
Secure Plus plan
Secure Trial Active
speaker
Talk
wired
Wmb4540
