  • 3256 Views
Boerneaggie
New Doorbell battery drains after about a week. Have charged it three times now and it lasted about the same each time. Very little activity has occurred in this timeframe
Boerneaggie
Reset of doorbell did the trick.  Thanks much.
greg
Are you using activity zones? If so, delete them to ensure you see ALL recordings since the servers discard recordings determined to be outside any zones.
Also try bringing the doorbell indoors for testing to see if there's a difference. It could be a signal strength/quality issue.
Boerneaggie
It is too soon to tell if the reset has resolved the issue.   In another week or so, will know.
Boerneaggie
greg
