Button notification only
I'm in an apt complex and people frequently walk by.
I want notification only when someone presses the button.
I know you can selectively turn off notifications for motion, person, etc.
If I turn them all off, will I still be notified when button is pressed?
Yes, the button is controlled in a different spot.
Another option is to disable notifications for the doorbell in the system modes (Armed Home, Armed Away, Standby). You can also remove the recordings there if you don't want them.
2nd Gen
Arlo 2nd Gen
Arlo Video Doorbell
audio
AVD3001
AVD4001
AVD4001-100AUS
communication
deta
Doorbell
drained battery
Feedback
homekit
intermittent
Mechanical chime
no app model
noise
Phonecall
reset
Secure Plus plan
Secure Trial Active
speaker
Talk
token
Video
wired
Wmb4540
