2K v HD What is the difference?
  • 5 Replies
  • 8889 Views
annos1
I want to purchase a wireless doorbell camera but I cannot find an explanation as to what 2K is.  I assume HD is high definition.  What is the difference?
@annos1 wrote:
 Is there any reason you might choose the lower resolution v. the higher resolution?
Higher resolution will show more details.
On the other hand, if you play back the recordings from a PC browser, the 2K/4K videos won't play on a old PC (~2015 or older), so you'd need to download them and play them in VLC or a similar software player.
5 REPLIES 5
HD: 1920x1080 resolution
2K: 2560x1440 resolution
4K: 2840x2160 resolution
annos1
So, the resolution is different.  Is there any reason you might choose the lower resolution v. the higher resolution? They are both the same price.
Edinburgh_lad1
Mentor
Mentor
But the gen 1 doorbell is lower in price when on offer, and allows local storage. Also, gen 1 has a replaceable battery. Mine is showing as 1,536 as resolution, so not a huge problem in terms of comparing it to the gen 2 one. Here's a test of both: https://eftm.com/2023/10/review-arlo-essentials-2k-video-doorbell-2nd-generation-a-bump-up-in-qualit...
