live stream using FireFox, chrome, etc, it tells me that flash needs to be updated
This is the worst product I have ever owned. I spent $1000.00 on a 4 camera system and have had nothing but grief since day 1!
Firmware update in July caused Audio detection to trigger randomly. How was that issue not found during development/QA??
Now I when I try to live stream using FireFox, chrome, etc, it tells me that flash needs to be updated but then I update it and the next time I log in I get the same issue. It looks like the UI was changed yesterday and looks like that introduced that issue. How was that not found during development/QA??
In the title bar in Chrome, click on the lock, go to Site Settings and allow Flash. That should solve your problem. I don't remember how I did it Firefox, but there is a way to allow Flash. I am no longer having your problem since I allowed Flash in both browsers. Arlo is actively working to get away from using Flash, but we don't have an ETA.
Brian
For FF, click on the "i" or lock icons to the left of the URL and disable Content Blocking.
I have done that but still every time I try to live stream one of the camera's I get this message: "A newer version of Adobe Flash player is required. Please install the latest version from here."
I click on "here", which is a link to the Adobe flash site. I download the installer and install it. I then go back into Arlo and try it again and I get the same message. Arlo broke something when they released a new UI a couple of days ago. The look and feel is slightly different.
On FireFox, I clicked on the little "block" icon next to the lock...click on allow flash... it's working fine here.
Yeah. The new icon appears after you click "Live" or otherwise try to use flash.
After you allow flash it changes color.
Then dismiss the update message by clicking the x and click "Live" again.
Yes, clicking on the little block fixes the problem but if you close and restart firefox and then try to live stream again you get the same update message again and have to click the box again.
It doesn't make sense...
It is ugly and tiresome, though to some degree that's on firefox (they should allow you to allow it persistently).
Of course what's needed is the transition to html5. Hopefully that will happen much earlier than Dec 2020.
Excellent. Works just as you said. The little lego icon next to the lock inthe upper left of the URL box.
But the person who logged the issue is correct. There is a whole a mile wide in the DEV/QA processes at Arlo.
Prove me wrong and send a patch Arlo.
Thank you gents
Actually it does make sense. If Arlo prioritizes this issue, it will get fixed and we will get a patch or an update.
So the only explanation is it's not a priority to Arlo or there would be a representative explaining how to fix the issue permanently.
Hit them with a massive DDOS attack and the prioroty may increase??? He he
@Mavrrick wrote:
They need to upgrade their web app to use HTML5.
No one here is saying otherwise.
Accessing Local Storage
