What features do you get after subscription?
Arlo ALTRA+ Series Can I use these cameras after my subscription has expired.The cameras do not show recordings in library.
Cloud storage requires a subscription. But you can use direct access to local storage instead. https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it
There are some limitations
- local recordings only available in the app
- local recordings not available to friends
- no manual recordings or snapshots
- no thumbnails
- remote access can be tricky to set up (you either need port forwarding or a VPN).
Also, you need a subscription for activity zones (when battery powered) and smart notifications.
Accessing Local Storage
