My base station is stuck on firmware 1.19.0.3_1237_68a8e53 and when you go into the settings to check the firmware it says "no updates available." Anyway to force an update / manually update without removing the base unit from my account? I can't view any locally recorded videos.
Hi @misterkash
I made an adjustment to your SmartHub, can you check to see if there is an update available now?
Try rebooting the hub. Also, what country are you in? Firmware may be rolled out by region rather than all at once.
Thanks for the suggestion, have rebooted multiple times, been stuck on this firmware for many months (maybe even a year), based in Australia.
I believe there is a solution for an Arlo Moderator to put my unit onto "production firmware" for it to update. Hoping @ShayneS can help!
Yeah, my cameras are mounted on a double storey home, so are not very accessible for re-enrollment once the base station is removed. So I'm really hoping this can be resolved remotely 😊
Hi @misterkash
Legend! Yes that worked! And it even auto-updated and is now on 1.21.1.0_1431_9611cf3 and with local saved clips working!
thank you for helping with this, I’ve been having this issue for literally a year and you helped resolve it in less than a day!
@misterkash : ) you are welcome
Sorry I wasn't able to solve this for you sooner, let me know if you have any other concerns and I will do my best to assist you.
Have a good one!
Hello,
Could you share what the fix is here? I think our system is have the same issue. I’m stuck on 1.16 with no option to update. Can’t install the security system I just purchased.
Thanks!
Are you still experiencing an issue, I see your devices are online at the moment.
no, I ended up deleting the base station and cameras from my account and reinstalled them. This forced the base station to update to the latest version.
Thank you for the update.
Accessing Local Storage
