  • 4 Replies
  • 1076 Views
Jefferies
I have taken a good look at other questions, and feel I still need to as.
Brand new Arlo Ultra. Base station set up and working, finding it on Laptop and Android. But when I try to link any of the 3 new cameras with it (I have also now charged them overnight just in case). Blue lights flash on camera and base station, but always fails to find. Camera is sitting by the base station. All I can think is it is a faulty base station and needs to be returned. I have reset the camera, and reset the base station. I have use the sync button both on the base station and camera multiple times. Always the same result. NO Camera Detected.
Yup, I'd swap at the store.
Be sure to try using the app to sync the cameras before attempting the sync button approach.
Jefferies,
Are there any other WiFi devices nearby? It could be due to a source of interference that is keeping the sync from successfully completing.
Jefferies
Yes, there is. Interesting. I will give this a try. Thank you. I did actually return the whole base and cameras, and the store was excellent in exchanging, but the exactly the same thing occurred with the new setup, base flashing blue and camera flashing blue, but no connection. Will try the above when I'm home from work.
Question, does the flow of data go from Router/Modem to the Base station, then base station to the camera? This is my understanding.
Jefferies,
The cameras do not communicate directly with your router. The cameras sync directly to the SmartHub and the SmartHub communicates with your home network through the wired connection to the router.
  • 4 Replies
  • 1077 Views
