HazzMatt,
New firmware has been released for camera and SmartHub along with new versions of the mobile app. Be sure you've updated to the latest versions and let us know if you still experience the same behavior.
Instead of pinch zoom, why not try a different video mode (switch between full (120 degrees), wide (155 degrees) or super wide (180 degrees))?
The issue of removing the zoom box when fully zoomed back out has been reported before. I don't recall for sure but I believe there was no resolution to the issue if Reset doesn't work. If an issue, you may need to remove and resync the camera to clear it.
No idea on the pinch zoom issue. Have you tried using a browser?
For all I know, it may simply be a glitch in the camera configuration. Rather than trying the same thing over and over with no resolution (see the definition of insanity by Einstein) reboot the base, remove and resync the camera. That should clear up any misconfiguration issues.
HazzMatt,
HazzMatt,
Great to hear, please let us know the results.
Using a WiFi analyzer app on my phone, I found that the Ultra base has a slightly higher output than my previous bases. Not enough to expect a difference but noticeable nonetheless.
I'm working closely with the engineering team investigating these reports. I will provide an update as soon as I have more information.
We apologize for any inconvenience caused and appreciate your patience as we work to resolve this issue.
ok thank you
New Arlo Ultra camera firmware is available addresses the issue being discussed here. Please make sure your camera is up to date with the latest firmware and let us know if you continue experiencing any stability issues.
Accessing Local Storage
