Resetting, reinserting the battery and all other troubleshooting methods have been depleted.
Has this ever been fixed or will I just need to take my business and everyone I know business as well elsewhere?
Seems to be ongoing issue that isn't fixed or will not be fixed for some reason.
Hi,
Are you still experiencing this issue?
I have 4 Arlo cameras, 2 are brand new. NONE of them have 2 way audio with the APP on my new phone, Samsung S21 Ultra. Evidently I'm not the only one.
Without this, I might as well send the new cameras back.
I created 3 chat support tickets, with NO RESPONSE from Arlo.
Help?
Hi @Xratchet13x
I have escalated your case & someone from support will be reaching out to you as soon as possible. I have provided your escalations number here: 43063028
Xratchet13x,
Yeah, I also intend to buy a different system when my FOUR cameras eventually fail. That's likely to be awhile, but this has been truly disappointing.
I'm hoping your 'escalation' yields some relief for you. If so, please let us know.
David Winship
@CodyG
May I ask what the issue is you are experiencing & which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I have reset and erased everything, nothing works. They were refurbished through Amazon, had I known that option didn't work I would have never bought them. Also, to note every 30 days you have to eject SD card and copy/paste recordings elsewhere. That way the direct storage access allows another 30 days of viewing. Why can't you just have a setting that starts your 30 days over and not have to go through the trouble of ejecting, deleting, rebooting etc. Like seriously, get some fn support already. People paid good money for crap.
I don't do that, and I always have access to the most recent 30 days of recordings.
Note this is a user-to-user forum, and I don't work for Arlo.
Understood, after this last update of firmware, which happened the other day my front door camera started working with 2 way audio.
I was stunned after owning it for over a year
But the 30 day thing may be the type of SD card I'm using. I'm going to try a different SD card per the specs and see what happens. Funny things is that the SD card I'm currently using was working until this current update.
I'll keep everyone posted.
Accessing Local Storage
