My Ultra Smarthub is continually going offline. I have tried powering down, resetting and removing the device. Once the device is re added it goes offline again within the hour.
When offline, what is the hub's LED showing?
The fastest thing to try, although a pain, is to remove all devices in Settings, My Devices and start fresh. I'd also press the reset button for >10 seconds until the LED flashes amber, too. Let the hub reboot to a solid blue LED and claim it fresh. Make sure you note all settings, modes, rules, etc. before doing this to speed the rebuild.
Hi Hareluya,
Have you tried the troubleshooting steps that jguerdat provided above?
If you're still having problems where your Base Station and/or camera goes offline, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Accessing Local Storage
