Notifications can be delayed for many reasons, including battery optimization for the app in the phone settings. Turn off battery optimizations.
Lag may be due to signal strength/quality between the camera and base and/or you upload speeds from your ISP. Use speedtest.net to check your speeds. There will always be a lag since you're viewing video from the servers, not directly from the cameras but should only be 2 seconds or so. What are your video settings for the camera in Settings, My Devices, your camera, Video Settings?
Also, be sure that you're changing your sensitivity settings in your modes and rules, not the motion test.
Wildcatnum1,
It could be an issue with the camera's location. Take a look at this article for tips on positioning for best performance: How do I position my Arlo Ultra camera to detect motion in specific areas?
Accessing Local Storage
