SMARTHUB IS OFFLINE. THE LIGHT GOES FROM SOLID BLUE TO FLASHING AMBER...HELP
Does power-cycling the base resolve it?
No. I’ve redone the Ethernet cable and power. Also reset the hub. The light turns blue then flashes amber. After some time it repeats blue then flashes amber. This happens continuously
JCERNIGLIA,
Try removing the smarthub from your account, factory reset, and then re-onboard as if it were a brand new device.
Follow the instructions here: https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-Base-Station
ALREADY TRIED. BASICALLY LIKE ITS A NEW SYSTEM. DOESN'T WORK
JCERNIGLIA,
This could indicate a hardware issue with the device. I encourage you to reach out to the Arlo Support team and open a ticket. You can find support options within the Arlo Mobile app under Settings > Support.
Accessing Local Storage
