What's everyone's thoughts on the system I'm considering, is it worth it for 350 shipped? Any major issues etc, is quality really considered 4k??
Thanks!
You can leave the exisiting system set up just as it is - you don't have to do anything else other than to set the new system up on your account. Be sure the seller has removed all devices from his account or you won't be able to install it.
The old cameras will work on the new system if you want. You just need to remove them (and, likely, the existing base) from Settings, My Devices before syncing them with the new hub.
dont get any of their 4k camera unles your ok with paying more for the 4k hardware and then paying monthly to access the 4k features - oh and the local storage only allows you to view if your home. complete money grab company find yourself a cheaper option and save the headache.
I have 4 4k Ultras and now they want me to pay 15 a month to record and view 4k over cloud (and half the time when streaming its not even 4k - only guaranteed 4k if your at home and have a good connection)
if your set on buying them u can buy my 4 camera setup with base and magnetic mounts
Man thank u again so very much, saved me!!
Accessing Local Storage
