Hi,
I was just wondering if someone could help me and tell me how to hard wire my arlo ultra camera that I have just purchased, I have checked on the web site and it does say it can be hard wired or wire free, but no instructions on how to hard wire it.
Many thanks for any help you can give, Lesley
You can buy an outdoor cable...
https://www.arlo.com/en-us/products/accessories.aspx
there are also 3 party adapters
Hi
many thanks for that info, ive just ordered one, found one on amazon in the uk. can I ask one more thing please, whenI do hard wire my camera should the battery be removed or left inside.
Either way. If the battery is left installed, the camera will still operate if the power is removed. For best functionality, use a UPS that will keep your modem, router and hub also powered during a power outage.
Thats great, many thanks for your help and advice.... Lesley
@Lesley-p wrote:
Hi,
I was just wondering if someone could help me and tell me how to hard wire my arlo ultra camera ...
I assume that you mean for power.
Just another user
Accessing Local Storage
