I purchased an arlo ultra system that came with 2 cameras, those two cameras synced easy and are currently working, I had purchased two add on cameras and those will not sync to the smart hub. I have went though the community and I have tried resetting the cameras, turning off all wifi, adding from pc and all of the community suggestions have not worked. But one community suggestion states that the firmware could be the issue and the serial number to the camera that will not work is A4219C74A0AFF if someone could verify if this is the issue that would be great.
Tell us what happened when you tried.
What did you do? Where did it go wrong and what messages did you see?
Just another user
Hey HarveyDavis,
Try referring to this article if your Ultra camera is not syncing to your SmartHub: My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
Try removing the battery from the Arlo Ultra cameras and then re-insert it back in again to try sync again to see if that helps.
Accessing Local Storage
