Today’s like most days. I have 17 recordings on the hub. 1 on the cloud. I was only notified of the 1 cloud recording. No notifications for the 16 other detected motions. ??
@L8RDave Do you smart notifications enabled. You wont get notifications for the ones off but will get recording. Such as if other motion is off you wont get the notification but will get the recording labeled "motion". Edit: I reread your post and that should not apply sorry.
Thanks for trying to help
I looked. Didn’t save to cloud but Did save to base station. This is a 1st!! However when I retrieved that vid I noticed 3 more had recorded without notice. So that’s 21 recordings
1 smart notification saved to cloud & Hub
1 generic Saved only to hub
So 19 on Hub with no notice !!!
Deplorable software.
HI @L8RDave
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Accessing Local Storage
