Night Color Vision
  • 2349 Views
rdbishop
Does Night Color Vision work without enabling the spotlight? If not, this isn’t really Night Color Vision at all.
Color requires much more light and a broader spectrum than what the IR LEDs supply. Use either the spotlight or external lighting to have sufficient light to enable color recording. Note that if you turn off the spotlight in the camera settings, color recording goes away.
rdbishop
Sounds like false advertising to me.
"Color Night Vision" doesn't have a crisp technical definition.  Every vendor I know of who uses this term will shift to IR (rendered as black and white) when the light level gets too low - though how dark "too low" is will vary.
The Ultra adds the spotlight, to allow more color recordings.  But it will take low-light color recordings w/o it if there is enough ambient light.
  • 2349 Views
