  • 8 Replies
  • 4966 Views
  • 3 Likes
GStanbury
For the last 2 days I have been unable to live stream any of my camera on Google home or iPhone or iPad. I have reset the system and reinstalled the app but this has not worked. I am on version 2.14 (72). I also cant play any videos from my library
Check to make sure your cameras are still participating in your Arlo Smart subscription. You can do this by logging in to the web client from a computer and navigating to Settings > Subscription > Manage cameras.
8 REPLIES 8
Budman2791
I’m having the same problems.
What are you experiencing that is preventing the live stream? Do you see any error messages?
Budman2791
If I try to access my video library in the IOS app or my windows computer I can see a form of screen shot but no video.  If I try to live stream from my IOS it gives the message "The device failed to connect.  Please try again."  If I try to access my live stream cameras from my Windows computer I get the triangle with exclamation point in the center that brings up the message "AC power has been disconnected from your Arlo device.  Activity Zones are currently disabled."  Also, I get a separate message that says "Maximum of 5 camera stream are supported simultaneously.  Please stop one stream before starting another camera system."  I only have four Arlo cameras so how am I getting the 5th one?  Any help that you can give would be greatly appreciated.  I have turned off power to the Hub, turned power back on;  I have also deleted my Arlo app and reinstalled it.  Suggestions?
Sarahhoux
I’m having the same problem. Started yesterday. Can’t see live view on any of my 4 cameras and notifications are only saving screenshots, not video clips. I’ve restarted the system and uninstalled/reinstalled the app But neither solved the problem. Every time I click play to see live view it says connecting and never connects any camera. Notifications now only say motion detected - doesn’t specify vehicle/person/animal. Again it’s just saving screenshots, no videos saving.
Sarahhoux
That fixed it! Thank you.
GStanbury
Thanks. That fixed the issue
Budman2791
That fixed my problem as well.  Any idea how this happened and what either myself or Arlo can do to prevent it from happening again in the future?
  • 8 Replies
  • 4967 Views
  • 3 Likes
