Hi.
Does Arlo Ultra SmartHub VMB5000 support SanDisk Extreme microSDXC 400 GB memory card? If not, what is supported microSDXC max size?
I really need a quick reply cause I'm just preparing an offer for monitoring system.
Regards,
Radek
tealootkey,
That SD card should work without any issues. See here for more details: How do I record 4K videos to a local storage device?
The only requirements are listed here:
VMB5000 accepts microSD cards, microSDHC, or microSDXC. We recommend that you use a microSD card with a minimum of 16 GB capacity, Speed Class 10, UHS1, V10. The Arlo SmartHub supports up to class 10 UHS-3 V90 class microSD cards.
Accessing Local Storage
