I am getting intermittent live 4K streaming issue. Most of the time I don’t get the 4K icon. I will only get 4K working a few times after I have removed and re-added the:
iOS app
Camera from the app
Base station from the app
This is not sustainable. Please fix this. I have 2 camera and they both have the same issue at the same time.
Hi del13r,
From looking at the screenshots you provided, it looks like the signal strength between your camera and your Base Station/SmartHub is getting a weaker signal, which could cause the 4K local streaming stop. Make sure that your cameras has full signal strength in the area that you intend to install them.
Thanks for sharing those screenshots. Try rebooting your iPhone 12 to see if that helps.
If you still see the issue, try uninstalling the Arlo app, reboot your iPhone again and reinstall the app.
I have tried both rebooting my phone and have removed the iOS app many times this week. I have even gone as far as removing the cameras from the base station and then the base station from my account and starting fresh. Still does not fix my issue.
Ok, I have no narrowed down the issue even further.
4K works for about 5 minutes after rebooting the phone 12.
After about 5 minutes, 4K refuses to work again until the next iphone 12 reboot.
Maybe try disabling cellular data (so it has to use the wifi connection), and see if that uses 4K???
Just as a test of course.
I just tested with cellular disabled a got no difference. I did however find that the 4K failure behaviour occurs when either the app goes out of focus by switching to another app or if I lock the phone. I can only get 4K working again if I close the app and relaunch it.
I would suggest for you to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Accessing Local Storage
