Hi,
I recently got an Arlo Ultra 3 camera system and am having some issues. I went to the video settings screen for 2 of my cameras, one the HDR setting and the other the video mode. As soon as the setting changed, the view of the video feed shows only the corner of the *real* video feed as if it's been zoomed and panned. If I view the live feed of the camera or a recording the video looks fine, but on the settings screen for these two cameras I can only see a part of the feed. Zooming or panning no longer works.
This means I can no longer set activity zones etc for those cameras.
The issue persists between the phone and web app including when I reinstall/clear cache etc. I have tried restarting my base station, to no effect. Changing the settings back to default has no effect.
Does anyone have a resolution to this issue? In other posts I have read that toggling auto zoom on and off (it is currently off) can fix similar issues, but this does not work for me.
The major issues being discussed in this thread have been resolved with the most recent Ultra Camera and SmartHub firmware updates. Please check here to make sure your systems automatically updated to the latest versions:
Arlo Ultra VMC5040 - 1.070.50.2_205_0c7c8e1 - 19th December 2019
Arlo SmartHub VMB5000 - 1.15.0.4_297_aa40f04 - 18th December 2019
If you're having a different issue, please open a new thread here in the community, reach out to me in a private message directly or contact support to further investigate: Arlo Support Team
A big thanks to the community for helping our engineering team troubleshoot these issues and thank you for your patience while we worked to release these updates.
Did you try taking a snapshot?
Hey did you figure out your problem? I am having the same issue where my camera would zoom to the left side of the screen and when you uncheck or turn off "Local Live 4k Streaming" it would then go back to normal. I believe this is affecting my Zone Activity causing false motion. My cameras and basestation is on the latest firmware. I'm thinking the last update is screwing the camera settings....
Unfortunately no, taking snapshots and other things and power cycling the cameras has not fixed this issue. I'm going to try and get in touch with arlo support.
Same issue started today when I wanted to finetune the settings. Brand new set purchased and installed yesterday. In the beginning of these evening there seemed to be no issue. Now nothing helps to solve the problem. Firmware etc. up to date. Arlo assistance is required I suppose.
My Arlo Pro cameras appear to have no problems.
The issues being reported here have been escalated to the development team and are currently being investigated. I will provide an update as soon as I have more information.
I also have this same issue, the activity. I attached a pic of the live view, and a view when trying to setup the activity zone (zoomed into the left corner).
Yes, I have restarted the Hub, updated the firmware, disconnected and reconnected the cameras and followed all other instructions I can find with this issue.
Hi JamesC,
Do you have any update about the issue? It is getting a bit annoying that the camera starts on all movements now I cannot set activity zones. The latest update did not bring any solution unfortunately.
Wimmus
Accessing Local Storage
