  • 5 Replies
  • 2590 Views
KS1979
Upon activating my system when leaving the house motion is detected an the system ”goes off”. This happens every time. I have to silence the sirens manually and then the system seams to function ok. I have had the problem for a few months now.
5 REPLIES 5
@KS1979 wrote:
Upon activating my system when leaving the house motion is detected an the system ”goes off”. This happens every time. I have to silence the sirens manually and then the system seems to function ok. I have had the problem for a few months now.
Are you seeing a motion recording in the library?  If so, is it from an indoor camera or an outdoor camera?
brh
@KS1979
You probably have the sirens activating in the rules section of the mode you are using. Be sure that they are deactivated in this mode. Now, if you want them to sound at other times and not in the mode you are currently using, create a custom mode and set the sirens to activated.
Brian
KS1979
There is no motion recorded. The two cameras that records ”nothing” are indoor cameras.
Is this in armed mode?
KS1979
The two cameras starts recording and the sirens goes off as soon as I arm them. The other two cameras in the system arms but doesnt go off. I disabled the sirens and that didnt do any good other than not activating the sirens when the system triggers.
  • 5 Replies
  • 2591 Views
