Hey, I used to live in the US and I bought 2 ultra cameras before I live, Im using it now in Saudi Arabia .. it works perfectly but when I want to subscribe plan nothing comes up, how may I store it in cloud? Ive been trying with the phone and the website but no plans comes in the page at all. I only can see that I have 2 cameras
Thank you
Unfortunately subscriptions aren't available in Saudi Arabia - https://kb.arlo.com/88/What-are-the-available-Arlo-subscription-plans-and-how-much-cloud-recording-i...
You might be able to overcome that with a VPN service that terminates in the US. The other option is to use direct access to local storage (which doesn't require a subscription).
On which:
What is Direct Storage Access and how do I use it?
Just another user
I also encountered the same problem. I purchased a VMS5440 Arlo Ultra 4 cam kit set from US and deploy it in Hong Kong. I could not find the 1-year free subscription option activated, I can only see the option to enroll new Arlo Smart or CVR plans.
How can I get my 1-year subscription back? 😞
Can someone please give a hand?
The bundled year is not transferable.
Here is the official response from @JamesC, in the middle of a discussion about the same thing:
Solved: Re: Arlo Ultra - Smart Plan - Arlo Communities
The free 1 year plan is only claimable in the country in which the system was purchased.
By the way, you have jumped on to the end of (hijacked) a discussion started by someone else on a different topic. For customised help, start you own discussion. That is more likely to get the attention of the Arlo team, which may well consider this one "solved".
Just another user
Accessing Local Storage
