I recently upgrading from Arlo Pro which I was reasonably happy with to Arlo Ultra and it's not been a good experience. Several of my cameras are nearly unusable due to constant green/pixelated recordings (screenshot attached). The worst one is hardware H6 with firmware 1.070.50.6_231_6e7e184. I have cameras with hardware versions H6-H10 in my system, my subscription is
I see a lot of people are having similar issues but I don't see any solutions posted. Now I see the "Ultra 2" which has 'better wifi range' and '2.4GHz/5GHz switching'. It's only been a few weeks since I spent $2,000.00 upgrading to Ultra to I cannot upgrade.
Is there a solution for this?
I occasionally get green images. I assumed it was when the camera lost WiFi or my router was down. Thankfully it doesn’t happen very often.
Hi @JasonFarque
Thanks for letting us know, After reviewing your screenshot & camera signal, it appears your Driveway & Front Porch camera are operating with a weak signal (1Bar). If you are able to move the SmartHub a little closer to these cameras your issue should go away.
the environment/wifi interference & construction of buildings can affect the signal strength. I have provided more info here: How do I position my Arlo wire-free camera?
Accessing Local Storage
