VMB5000 Connection issues after falling down
  • 1 Reply
  • 2270 Views
Ewiok
Have a Arlo Ultra Smarthub VMB5000. It has problems with connections to cameras. The station has sadly fallen to the floor and after that the problems started. Thinking it can be problems with the antennas inside the box. Closest cameras work but the cameras far away cant connect any more. Is the antennas soldered or just the normal antenna connections that can be found in laptops and other products with antennas? If open just push the connection back or need to solder?
The station is far away and want to know how to do this and get the correct tools before trying to fix this.
Someone who has done any form of surgery on VMB5000 and can help?
I would pick up a new 5000 base and swap them....later if you get it to work, you’ll have a spare ( or can run two bases )
  • 1 Reply
  • 2271 Views
